Reversing normals with center of a primitive
Hey Guys!
I have those wonderful walls going through a for each loop and some of my normals and faces are reversed at the end.
I was thinking about getting the center of each prim and use a wrangle to reverse the normals but not quite sure how to approach that.
Thanks for the help.
i have bang my head a lot with some shitty mesh coming from C4D. the most effective way i found,  that work more than 95% of the time was to.
loop each pieces, close them, convert to vdb then compare N with Grad and invert the direction if they are not the same.
it might work in your case.
clean_normal.hiplc
Edited by sebkaine
  • Thanks 1
