Alain2131 Posted November 19, 2022 Share Posted November 19, 2022 (edited) Hello ! I want to "write out" an array variable to discrete float/int attributes (in the format a[0], a[1], a[2], a[3], a[4], a[5], etc). In the Geometry Info, it'd be reported as "a 6flt", as opposed to "a flt[]". I was able to create such an attribute using attribcreate (just set the Size to whatever value). And then, in VEX, the attribute is represented as an array (read using point()). I can change the content, but to write it out I had to use the setpointattrib() function. The f[]@a syntax did nothing, both for reading the attribute, and writing it out. I was able to get the size using the pointattribsize() function. arbitrary_size_float_attribute.hipnc Is there a way to create a float/int attribute of arbitrary size in VEX, like the attribcreate does ? A few constraints : The size is known beforehand. I cannot use the attribcreate node. I want to use the @ syntax for speed, but will settle with setpointattrib() if I can't. A solution could be to write it as an array attribute, then extract that array into a float/int attribute of a fixed size. But I don't know how to do that. Thanks ! Edited November 19, 2022 by Alain2131 Quote Link to comment Share on other sites More sharing options...
bunker Posted November 19, 2022 Share Posted November 19, 2022 1 Quote Link to comment Share on other sites More sharing options...
