JJ FX Posted December 6, 2022 Share Posted December 6, 2022 Hi, I need to get all parms of a node structured like an object, going from top folder down. Here's a pseudo-code structure I'm looking for: parm_obj = { "name": "parm_name", "type": int/float/bool, "min": value, "max": value, "value": some_value } folder_obj = { "name": "folder_name", "type": tab/collapsable/simple "folders": [folder_obj_1, folder_obj_2, ...], "parms": [parm_obj_1, parm_obj_2, ...] } node_parms_obj = { "name": "node name", "folders": [folder_obj_1, folder_obj_2, ...],, "parms": [parm_obj_1, parm_obj_2, ...] } Because folders contain more folders it gets quite tricky. So I need recursive functions for that. But I'm failing so far. I've looked into docs and I'm surprised that there's no method for that already! Or am I missing something? Maybe there is? Do you guys have any tips on how to deal with it? Quote Link to comment Share on other sites More sharing options...
JJ FX Posted December 6, 2022 Author Share Posted December 6, 2022 (edited) Here's my solution straight from hell. It's not fully cleaned up yet. Using PrettyPrinter because it's difficult to tell if it's even working. I guess I'd have to plug it into the another endpoint to see if it's working for me. import pprint pp = pprint.PrettyPrinter(indent=4) # [1] Settings node = hou.pwd().input(0) # tested with python sop excluded_folders = ['Top Folder One', 'Top Folder Two', 'Another Not Used Folder'] use_folders = ['Settings', 'Another Folder Name'] # [2] Defs # parm object example parm_obj_template = { "name": "parm_name", "label": "parm_label", "type": "type", "min": 0, "max": 0, "value": 0 } # folder object example folder_obj_template = { "name": "folder_name", "label": "parm_label", "type": "type", "folders": [], "parms": [] } parm_types = [hou.parmTemplateType.Float, hou.parmTemplateType.Int, hou.parmTemplateType.Toggle] folder_types = [hou.folderType.Collapsible, hou.folderType.Simple, hou.folderType.Tabs] def __is_parm(parm): return parm.type() in parm_types def __is_folder(parm): return parm.type() == hou.parmTemplateType.Folder def __get_parms(folder): return [parm for parm in folder.parmTemplates() if parm.type() in parm_types] def __get_folders(folder): return [parm for parm in folder.parmTemplates() if parm.type() == hou.parmTemplateType.Folder] def __get_parm_obj(parm): data = {} data['name'] = parm.name() data['label'] = parm.label() data['type'] = parm.type() data['min'] = parm.minValue() data['max'] = parm.maxValue() data['value'] = node.parm(parm.name()).eval() return data def __get_folder_obj(folder): data = {} data['name'] = folder.name() data['label'] = folder.label() data['type'] = folder.folderType() data['parms'] = [] for parm in __get_parms(folder): data['parms'].append(__get_parm_obj(parm)) pass data['folders'] = [] for subfolder in __get_folders(folder): if __is_folder(subfolder): data['folders'].append(__get_folder_obj(subfolder)) pass return data # [3] Run group = node.parmTemplateGroup() top_folders = [folder for folder in group.entries() if folder.type() == hou.parmTemplateType.Folder] included = [folder for folder in top_folders if folder.label() not in excluded_folders] def node_obj(): data = { 'name' : node.name() } folders = [] for folder in included: folders.append(__get_folder_obj(folder)) pass data['folders'] = folders return data print('\n-> Start') pp.pprint(node_obj()) print('End <-') Edited December 6, 2022 by JJ FX Quote Link to comment Share on other sites More sharing options...
JJ FX Posted June 14, 2023 Author Share Posted June 14, 2023 (edited) Recently I had to revise the code, as it was quite a mess. I had no idea what what going on. So I refactored and here's a much better solution. Still I'm only using parmTemplates of Float, Int, Menu, Toggle. Also the code might not work for multiparms. I decided to limit to have only a single disableWhen condition - so there are no detections on that in the code. Rebuilding multi conditionals in the frontend is not straightforward and only confuses the user. Just import types.py into parms.py and you're good to go. Parms('your_node').data will return a JSON with well structured parameters in folders. Quite cool thing if you want to rebuild the frontend in some web application. parms.pyFetching info... types.pyFetching info... Edited June 14, 2023 by JJ FX Quote Link to comment Share on other sites More sharing options...
