houdini random offset
jisun
You can use the chop expression.  First, you ahve to determine the name of the CHOP channel... in CHOPs, middle click and you should see the channel name is "chan1."  So in your offset parm:
chop("/obj/chopnet1/warp1/chan1")
Hope that helps!
Sean
