Message And Timer For A Long Cook
My SOP node is cooking long time.
I think it'd be great to add a dialog about what is happening and ability to interrupt it, but I can't get how to do that.
I've tried to redefine OP_Node::getCookTimerLabel() and use start/stopCookTimer() inside my cook method, but dialog still doesn't appear...
And, as an ability to interrupt cooking process, I should periodically check wasInterrupted() function, right?
take a look at this sop
uv uniform
It uses the cooking dialog and interrupts from UT_Interrupt.h
UT_Interrupt		  *boss;
//check for user interrupts
  boss = UTgetInterrupt();
  boss->setEnabled(1, 0);
  boss->setAppTitle("UVuniform");
  boss->setLongOpText("Fetching uvs");
  boss->setLongPercent(0);
  boss->setInterruptable(1);
  boss->setLongOpText("smoothing grid");
  boss->setLongPercent(0.1);
  test = boss->opInterrupt(5);
Edited by sibarrick
Thanks, that helped a lot!
uv uniform
UT_Interrupt		  *boss;
