DeBrumaire Posted February 3, 2023 Share Posted February 3, 2023 Hello everyone ! I'm currently learning OpenCl. And I found that for a very simple code, OpenCl creates a different result compared to VEX. I'm trying to get the average position of near points and create a vector that aims toward this mean position. In VEX, it works as I expect it to work: But in OpenCl it does this weird approximation: For the projects I'm working on, I need my vectors to be precise... Do you know why it behaves this way ? Thank you all ! Quote Link to comment Share on other sites More sharing options...
DeBrumaire Posted February 3, 2023 Author Share Posted February 3, 2023 I forgot to share the .hip file above ! Here it is ! OpenCl_Weird_Vectors.hipnc Quote Link to comment Share on other sites More sharing options...
Alain2131 Posted February 3, 2023 Share Posted February 3, 2023 Salut Mattéo ! The issue is from current_pos I figured it out by simply exporting each of your float3 attributes into your force attribute, and comparing the result with VEX's. sumPos has the exact same result, whereas current_pos is different. Which, if you take a closer look at the line where you load it, you used vload() instead of vload3() ! Quote Link to comment Share on other sites More sharing options...
DeBrumaire Posted February 3, 2023 Author Share Posted February 3, 2023 Salut Alain ! Merci pour ta réponse ! Yeah I didn't see this innacuracy thanks ! x"D Quote Link to comment Share on other sites More sharing options...
