Use Camera Path Expression In Parameter Channel [SOLVED]
I have a very basic scene with a master control null, one camera and I'm also using the qLib camera frustrum node.
The master control null just has one operator path string where I can input the camera.
On the qLib camera frustrum node, it's easy to link the camera to the path on the master control null, but how can I link the near / far attributes, without directly pointing to the actual camera, like I've done here:
I can't work out how to include the `chsop("../CONTROL/cam")` part of the expression into the near / far fields.
My overall aim is for someone to be able to just input a camera into the master control null (no matter what the camera is named) and have the camera frustrum update to the correct camera, as well as the near / far clipping planes.
.hip file attached.
link_camera_expression.hiplc
Edited by GlennimusPrime
  • GlennimusPrime changed the title to Use Camera Path Expression In Parameter Channel
ch(chs("camera")+"/near")
ch(chs("camera")+"/far")
... should do the trick.
A more elegant way of doing what you are doing might be to plug the cam into the node.  I don't have the node definition though, so not sure if this will work with the transforms and all... but maybe changing "space" to "camera space" and this will work:
Edited by mrCatfish
  • Thanks 1
  • GlennimusPrime changed the title to Use Camera Path Expression In Parameter Channel [SOLVED]
