bentraje Posted March 18, 2023 Share Posted March 18, 2023 Hi, I have a wedge attribute through TOPS that goes from 0 to 9. If I input `@wedge` on a group paramater, it works. The group value changes depending on the work item active/selected. As expected. But if I put this in an attribute wrangle. It will always stay zero. Is there a way to make the attribute wrangle also dynamically update? You can check an illustration below: wedge.mp4 debug_wedge_attribute_on_vex.hipnc Quote Link to comment Share on other sites More sharing options...
