dubCUT Posted April 10, 2023 Share Posted April 10, 2023 (edited) hello i try to manipulate every point rotation by the curve using @ptnum. so every point could rotate different, based on the curve. why isn't it working? only 0 and 1 on the curve have an effect. and it results in the same rotation on all points. is there any obvious mistake? EDIT: SOLUTION: float value = i@ptnum * (1.0 / i@numpt); rotate(4@localtransform, (chf("Value")*0.1)*chramp("Remap",value), chv("Axis")); the fit was not needed and it was necessary to introduce a float (1.0) into the division for it to work. Edited April 10, 2023 by dubCUT Quote Link to comment Share on other sites More sharing options...
