masstapro Posted April 7, 2007 Share Posted April 7, 2007 Have a flower, want to Bend each pedal. Pedals are seperate SOP level objects that are positioned in a circle around stem. Want to use the Twist/Bend SOP but it's Pivot Rotation isn't where I'd like it to be and can't get the sucker to move, only Transform, no Rotation. This means I can't line up the AXIS for the Bend to the proper pedal location. Thought there was an easier way do this besides moving each pedal to a World location, then back to the FLower Stem location. ~Shawn Quote Link to comment Share on other sites More sharing options...
masstapro Posted April 19, 2007 Author Share Posted April 19, 2007 Okay, I found an easy work around this problem. Append a transform sop. Position object so it's in desired position for manipulation. Right Mouse Buttom click transform sop and select Reference Copy. Wire new transform sop after manipulation op (I'm using a bend operation). Right Mouse Button click on Invert Transformation, select Delete Channels. Now Enable Invert Transformation. Blam! done! ~Shawn Quote Link to comment Share on other sites More sharing options...
