ml deform and houdini
anichar
  • 3 weeks later...
  • 4 months later...
Only part that is done in Maya, is generation of training ROM.  In Maya there is a script that takes your skeleton, you define degrees of freedom for every bone in body, and generates N number of randomly generated poses. You can do that on your own in Houdini or any other software and export as FBX.
That ROM fbx is referenced in houdini, and from that point there is no any attachments with maya anymore.
UE 5.2 presentation uses Vellum, it's not Ziva.
Let me know if you have more questions.
Cheers
C
  • 2 weeks later...
  • 1 month later...
@vinyvince There is no need for the first part to be done in Maya. Main reason is that all pipeline other than simulation is in Maya. Also some advanced nodes needed for scapula rigging, like RBF pose driver and other used, were more convenient to do in Maya at the time, than import baked FBX in Houdini and drive skeleton that way.
But if you want to rig skeleton using kineFx in Houdini you can, there is no reason not to do it that way other than p[personal preferences.
