gregjenings Posted May 22, 2023 Share Posted May 22, 2023 How can I utilize PDG in Houdini software to create a flipbook with multiple cameras, and then generate a mosaic of those flipbooks using the ImageMagick node in PDG? Additionally, how can I incorporate OpenGL to render my flipbook? Quote Link to comment Share on other sites More sharing options...
Lazar Lukic Posted June 15, 2023 Share Posted June 15, 2023 Hi gregjenings I'm not quite sure whay you mean by incorporating OpenGl into flipbook, But this might help you out a bit. This is a setup for generating OpenGl (Gpu) or Mantra (Cpu) sequences that can later be added together in a single preview using the composite network. test_OpenGL.hipFetching info... Quote Link to comment Share on other sites More sharing options...
