Particle Fluid Surface generate interior geometry in some frames
martinchumillas
Hi! I have a problem with the particle fluid surface node. In some frames it generates another layer of geo in the inside where there should be nothing.
In the photos you can see one frame an the next one. In the first one there is this geo and the other one is ok.
I would appreciate a lot your help!
