martinchumillas Posted June 11, 2023 Share Posted June 11, 2023 Hi! I have a problem with the particle fluid surface node. In some frames it generates another layer of geo in the inside where there should be nothing. In the photos you can see one frame an the next one. In the first one there is this geo and the other one is ok. I would appreciate a lot your help! Quote Link to comment Share on other sites More sharing options...
Lazar Lukic Posted June 15, 2023 Share Posted June 15, 2023 Hi martinchumillas It is hard to tell what exactly is causing the issue here, Could you maybe share you hip file so we can get more information about the problem. Quote Link to comment Share on other sites More sharing options...
