Oceanfoam displacement issue with H19.5.642
Hello!
Not sure if I'm doing something wrong here, but when I enable noise under the Mask tab in ocean spectrum, the ocean foam generates foam
that doesn't align properly with the surface. However, if I use another ocean evaluate node (ocean foam into ocean evaluate) and disable displacement in the ocean foam node, it
seems to work. Not sure how to go about this correctly?
Thanks!
