gregjenings Posted June 30, 2023 Share Posted June 30, 2023 I was trying to use a texture map with Karma Hair Shader but unfortunately Failed to receive the resulting texture to the fur. I highly appreciate it if someone guides me the correct method to apply texture maps in the Karma Hair shader. Quote Link to comment Share on other sites More sharing options...
supermonkey Posted January 1, 2024 Share Posted January 1, 2024 (edited) Do you have normals on the curves? If you're doing ribbons they are auto generated but if you're rendering curves as tubes you need normals on the curves and then karma will auto calculate the uvs. Believe this is exclusive to h20 Edited January 1, 2024 by supermonkey Quote Link to comment Share on other sites More sharing options...
