jisun Posted July 18, 2023 Share Posted July 18, 2023 I want to control drawcurve with subnet. But I don't think I can control what's inside the subnet. I need help. I'll attach the file. subnet.hipFetching info... Quote Link to comment Share on other sites More sharing options...
lynloveyounever Posted July 24, 2023 Share Posted July 24, 2023 You can create a button parameter on the subnetwork interface, and set the Callaback Script to make any node into current/selected(replace the "box1" to your node name ). when you finsh create and click button, parameter interface will be change to the node ,that is the one you assign in the script.Finally, move your mouse to the scene view window, hit "enter" to active node. Quote Link to comment Share on other sites More sharing options...
