nepogiqi Posted July 29, 2023 Share Posted July 29, 2023 Hi, I'm making a wheels animation. The wheel travels on a road and rotates depending on the speed it goes. Everything looks normal. But when I come to "Francitonal Frames" with "timeBlend" (depending on the speed of the wheel) there is a change in the size of the wheel. Likewise, when I export as Alembic and import again, I have the same problem. I hope you can help me with this. Thank you from now. den.hipnc Quote Link to comment Share on other sites More sharing options...
bengaet Posted July 30, 2023 Share Posted July 30, 2023 turn on pointnumbers to see where the points actually go, i assume it's because they are interpolating linearly between two points which means they take the fastest way to get to the position instead of keeping the rotation arc. do you even need the timeblend node for interpolation? i think if the transform happens in houdini anyway, it should automatically be able to correctly calculate subframes? in case you are using frame expressions somewhere, make sure to use $FF (float frame) instead of just $F Quote Link to comment Share on other sites More sharing options...
