shadowst17 Posted September 15, 2023 Share Posted September 15, 2023 (edited) Hello, I'm trying to run a python script that does some code, runs a TOPS and then waits for said TOPs to finish then continue the rest of the script. Any ideas on how I could go about that? I've tried time but i guess it's on the same thread so it freezes Houdini. Here's a simplified script giving you the gist of what I'm looking for. import hou import time node = hou.selectedNodes()[0] hip = hou.hipFile.path() hou.hipFile.save(hip) node.parm("cookbutton").pressButton() time.sleep(2) cooking = True failed = False while cooking: for i in range(60): if node.getCookState(1) != hou.topCookState.Cooking: print("Cook finished") cooking = False break time.sleep(2) if node.getCookState(1) == hou.topCookState.Cooking: print("Times up") failed = True cooking = False print("Continue the rest of the script") SOLVED: Using the .CookOutputWorkItems(block=True) solved my issue. Edited September 15, 2023 by shadowst17 Quote Link to comment Share on other sites More sharing options...
