komar93 Posted September 26, 2023 Share Posted September 26, 2023 Hello, I face the problem with transferring in the right way simulation, to Unreal Engine. Generally speaking, I want to make the cylinder with small candies inside (like a snow globe), simulate those physics in Houdini, and move it to UE5 (Don't wanna simulate that in UE physics). The final effect is player can grab the bottle (cylinder) rotate it and see how the pills move inside the bottle. I tried with Vellum and it works with particles but not work after moved with VAT textures to Unreal. Second try I was thinking of doing like 2 or 4 animations/simulations and transferring there to animated FBX? Not sure how to do it correctly, can someone give me a tip on how to do it properly? Quote Link to comment Share on other sites More sharing options...
Drunkenpanda Posted September 26, 2023 Share Posted September 26, 2023 (edited) I dont think FBX is the correct format here. Have you tried using vertex animations ? https://www.sidefx.com/tutorials/vertex-animation-textures-for-unreal/https://www.sidefx.com/tutorials/vertex-animation-textures-for-unreal/ Edited September 26, 2023 by Drunkenpanda Quote Link to comment Share on other sites More sharing options...
Wesley Clayton Posted November 28, 2023 Share Posted November 28, 2023 Have you ever used animations from Vertex? Quote Link to comment Share on other sites More sharing options...
kapsgij Posted August 20, 2024 Share Posted August 20, 2024 On 11/28/2023 at 8:55 AM, Wesley Clayton said: Have you ever used animations from Vertex? I agree with the comment above, did you try using animations from Vertex? if so, did it help? Quote Link to comment Share on other sites More sharing options...
komar93 Posted September 10, 2024 Author Share Posted September 10, 2024 On 8/20/2024 at 1:50 PM, kapsgij said: I agree with the comment above, did you try using animations from Vertex? if so, did it help? The best way was to set it up inside Niagara :) Quote Link to comment Share on other sites More sharing options...
