Adjust the scale of a transform (9flt) attribute
kube
Hey,
I have a basic curve KineFx Rig and I´m copying spheres onto the curve.
The problem is that I can´t randomize the uniform scale of each sphere because the transform of the rig curve controls the scale of the spheres, so simply adjusting the pscale doesn´t work.
So how do i uniformly randomize the scale of the 3x3 tansform attribute? I tried something with a pointvop but the spehers are not being scaled uniformly.
HIP file is attached.
TRANSFORM_ADJUST_SCALE.hipnc
Edited by kube
Hey Kube,
you can make your attribute and then scale the sphere by it. That way, Houdini's naming system won't get in the way. Here are the changes I made to your hip file:
1. Attribrandomize2 SOP - I changed the name to myTransform and changed the dimensions to 1, since you said you wanted to scale the sphere uniformly. You can keep it a vector if you want the spheres to be squished.
2. get_attribute Null - This is where the next node will point to
3. transform SOP - put the pivot in the center of the object with the centroid function. Use the "myTransform" attribute to scale the object with this point("../get_attribute", 0, "myTransform", 0)
I hope this helps because I don't know how to randomize the scale of the 3x3 transform attribute
TRANSFORM_ADJUST_SCALE_fix.hipnc
  • Thanks 1
14 hours ago, RobiDoes3d said:
Hey Kube,
Hey Robi,
that really does the trick, thanks man!!
  • Thanks 1
