Point Instancing
Say, there is a particle system in object A.
Every particle has Scale, UpVector, ID attribute.
If i switch object A to Point Inctance mode and choose object B
as an inctance, then during render process Houdini replaces
every particle with object B and scales it
according to $PSCALE attribute.
BUT! It does not rotate them according UpVector, though docs say it should:
"If an up vector exists for the particles,
it will be used to orient the instanced geometry.
You create and control up vectors for particles by using a Point SOP."
So what am i doing wrong?
Say, object B contains only a Bounding box,
while it is switched to Bounded File(BBox from render SOP) mode,
where a special application is called as a file which
generate object dynamically.
So is it possible to transfer particle's parameters
(for which application is called) like Scale,ID,Current Time
to this application as arguments ?
