SpencerL Posted May 2, 2007 Share Posted May 2, 2007 (edited) Hello, This is a problem that Ive had for sometime with DOPs and obj merging the geo back into SOPs and it could be because Im missing something. Basically, I have a wire simulation that I merge into SOPs using an object merge SOP with the syntax ../dopnet1:wireobject1/Geometry That brings in the geo from DOPs fine, but if I go and change something inside DOPs, it seems to break the obj merge into SOPs and the only way to bring my geo back into SOPs is by re-entering in the object merge SOP ../dopnet1:wireobject1/Geometry is there a way to force the merge if a change happens, or am I just doing something fundamentally wrong here. Thanks Edited May 2, 2007 by SpencerL Quote Link to comment Share on other sites More sharing options...
