Uv Attribute From Internal Uv
HI..........
How to find the value of a point attribute at an In between point on a Primitive with UV ????
Basically I have an Input GDP with number of polygons., and a UV attribute. For any Internal uv value , I want to find out what is the UV Attribute value at that point. This is no problem for NURB Surface as Internal uv and
UV attribute are same. But for a polygon object, how can I access UV attribute from internal uv.
I thought, I can be done with "evaluateInteriorPointWAttrib", but don't know how to use it.
Waiting for ur Reply.
Edited by iamjaideep80
