Carve A Nurb Curve Using Hdk
Hi.....
I want to carve a Nurb Curve in HDK , like a Carve SOP. I have a pointer to the"GU_PrimNURBCurve".
I think the "cut" function in GU_PrimNURBCurve class does the same thing.My Code is something like,
GU_Curve* newNurbcurvePtr = 0;
int ind1 = 0;
int ind2 = 0;
newNurbcurvePtr = nurbcurvePtr->cut(myU(),myV(),ind1,ind2,0);
the "keep" flag is off. So it should modify my source curve. It is not doing that. Also it is not giving any outpout, as value of newNurbcurvePtr remains 0 after the function. If i use 1 as "keep" flag then also the value is 0.
I don't know what the Index parameters ind1 and ind2 are for, but they are also not changing . If anybody knows plz explain.
Edited by iamjaideep80
  • 1 year later...
