Calculating Center Of Curvature Of A Curve
is there any SOP or VOP that that can output the center of curvature for a curve at a given point along the curve? This function would be equal to maya's pointOnCurveInfo node.
The math for this is a bit beyond me...
Thanks,
MD
Sure, you can either use the Measure SOP and output curvature as attributes on geometry, or use the "curvature" expression:
/obj -> exhelp curvature
float curvature (string, float, float, float)
			usage
				curvature(<<SOP>>, <<prim_num>>, <<u>>, <<v>>)
			Evaluates the curvature of the surface at the parametric (u,v)
			location. u and v are unit values, defined in the [0,1] interval.
			NOTE:
				if the primitive is a mesh, u and v are defined in terms of its
				number of rows and columns.
			related
			  - unituv
			  - primuv
			  - primduv
			  - normal
perfect!, Thank you
MD
			usage
			NOTE:
			related
			  - unituv
			  - primuv
			  - primduv
			  - normal
