Aligning curve start point of multiple curves
Hello,
I'm working on a custom g-code slicer and one problem I encounter is that I don't know how to align the curve start/end points of vertically stacked closed curves. I want the start points to be close together, to minimize the travel between layer changes and to move the seams to the back of the print. I've attached a simplified example with two curves, one of them rotated. I want to check and rotate each of them so that the start point is the point that has an x-coordinate closest to x=-1. Just for demo purposes here.
I am doing the point sorting in an attribute wrangle which has multiple problems I'm afraid. I hope someone can help me out. I checked these solution but they all work with simple shifts, I need to shift each curve differently.
Here's the vex:
for(int c = 0; c < nprimitives(0); ++c) {
    float minX = -1;
    int minIndex = -1;
    float minDistance = 1e30;
    int cPoints[] = primpoints(0, c);
    int numPoints = len(cPoints);
    for (int i = 0; i < numPoints; ++i)
        vector P = cPoints[i];
        float distance = abs(P.x - minX);
        if (distance < minDistance)
            minDistance = distance;
            minIndex = i;
    int newIndexArray[] = array(numPoints, 0);
        newIndexArray[i] = (minIndex + i) % numPoints;
        // that would break for curves with different point counts:
        setpointattrib(geoself(), "newindex", i + (c * numPoints), newIndexArray[i], "set");
I know one problem is mixing absolute point index and index within primpoints but I don't know how to best solve it.
align_curve_starts.hipnc
Hello,
if you have a set of curve (I would prefer always closed ones, so no you don't have repeating points), you can measure the the distance between all point pairs and sum them up and doing this for all offsets (0, 1, 2, ... number of prim). After this there should be an optimal offset (with minimum distant sum). You can do this for all curve pairs and get the relative offset from curve i to curve i-1 etc... .
align_curve_starts_mod.hipnc
Edited by Aizatulin
If the point number per prim is different, you can workaround it by resampling all primitives with same count. After this you can capture each point from the original curve using xyzdist() and reorder the vertices based on their u-param. It may be a bit less accurate.
align_curve_starts_modA.hipnc
Edited by Aizatulin
