Wedging channel ramp parameter
How do I wedge in TOPS a channel ramp parameter. Considering a channel ramp parameter has three controls to it, the Point Number, Position & Value. My solution is to make three wedge nodes in tops, two floats and one integer and merge them together, using a merge top. There is only one problem, the point number how do I access the wedge; I can place a wedge attribute for the two floats of a channel ramp parameter but not for the integer ?
