snailfish Posted May 27, 2007 Share Posted May 27, 2007 Hello everyone without any luck I've tried to make a ball bounce on top of a animated pin table. I've used volume based collision on the pin table to make the ball interact with the pins. This has so far not given me any good results. Is there any other way to make the ball collide with the pins? See attached hip file for reference. erik pintable_v1r3.hip Quote Link to comment Share on other sites More sharing options...
MIguel P Posted May 27, 2007 Share Posted May 27, 2007 You have to turn on "Use Point Velocity for Collisions" in the rbdsolver. But you will need a ground with more resolution or add a Ground Plane DOP. Quote Link to comment Share on other sites More sharing options...
snailfish Posted May 27, 2007 Author Share Posted May 27, 2007 [quote name='MIguel P Quote Link to comment Share on other sites More sharing options...
