Very Simple Question_how Tho Display The Instance Obj In Pop?
sprawd
Currently not possible except in the POP viewer.
You can use a Copy SOP and feed in your target instance geometry in the left and your particles in the right. The Copy SOP uses the same attributes (pscale, scale, v, n up) as mantra instancing to both orient and size the instances.
