khasperha Posted May 29, 2007 Share Posted May 29, 2007 Hi I've got a wildcat realizm 100 cg. I follow the install driver and modif xorg.conf But no acceleration !!! I tried RHEL4 and CentOS 4.5 same problem! glxinfo name of display: :0.0display: :0 screen: 0direct rendering: Yesserver glx vendor string: SGIserver glx version string: 1.2server glx extensions: GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_OML_swap_method, GLX_SGI_make_current_read, GLX_SGIS_multisample, GLX_SGIX_fbconfigclient glx vendor string: SGIclient glx version string: 1.4client glx extensions: GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_allocate_memory, GLX_MESA_swap_control, GLX_MESA_swap_frame_usage, GLX_OML_swap_method, GLX_OML_sync_control, GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync, GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_groupGLX extensions: GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_SGIS_multisampleOpenGL vendor string: 3DlabsOpenGL renderer string: Wildcat RealizmOpenGL version string: 1.5OpenGL extensions: ARB_imaging, GL_ARB_depth_texture, GL_ARB_fragment_program, GL_ARB_fragment_shader, GL_ARB_half_float_pixel, GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_occlusion_query, GL_ARB_point_parameters, GL_ARB_shader_objects, GL_ARB_shading_language_100, GL_ARB_shadow, GL_ARB_texture_border_clamp, GL_ARB_texture_compression, GL_ARB_texture_cube_map, GL_ARB_texture_env_add, GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3, GL_ARB_texture_float, GL_ARB_texture_mirrored_repeat, GL_ARB_texture_non_power_of_two, GL_ARB_transpose_matrix, GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader, GL_ARB_window_pos, GL_EXT_422_pixels, GL_EXT_bgra, GL_EXT_blend_color, GL_EXT_blend_func_separate, GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_color_matrix, GL_EXT_color_subtable, GL_EXT_color_table, GL_EXT_convolution, GL_EXT_convolution_border_modes, GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_fog_offset, GL_EXT_generate_mipmap, GL_EXT_histogram, GL_EXT_interlace, GL_EXT_multi_draw_arrays, GL_EXT_multisample, GL_EXT_packed_pixels, GL_EXT_rescale_normal, GL_EXT_secondary_color, GL_EXT_separate_specular_color, GL_EXT_shadow_funcs, GL_EXT_stencil_wrap, GL_EXT_texture3D, GL_EXT_texture_border_clamp, GL_EXT_texture_color_table, GL_EXT_texture_compression_s3tc, GL_EXT_texture_edge_clamp, GL_EXT_texture_env_combine, GL_EXT_texture_filter_anisotropic, GL_EXT_texture_lod, GL_EXT_texture_lod_bias, GL_EXT_texture_object, GL_Autodesk_valid_back_buffer_hint, GL_HP_occlusion_test, GL_I3D_argb, GL_I3D_interlace_read, GL_IBM_cull_vertex, GL_IBM_rescale_normal, GL_NV_blend_square, GL_NV_texgen_reflection, GL_OML_interlace, GL_SGI_color_matrix, GL_SGI_color_table, GL_SGI_texture_color_table, GL_SGIS_generate_mipmap, GL_SGIS_multisample, GL_SGIS_texture_border_clamp, GL_SGIS_texture_color_mask, GL_SGIX_interlace, GL_SGIX_fog_offset, GL_ARB_shader_objects, GL_ARB_vertex_shader, GL_ARB_fragment_shader, GL_ARB_shading_language_100glu version: 1.3glu extensions: GLU_EXT_nurbs_tessellator, GLU_EXT_object_space_tessInstruction ill Quote Link to comment Share on other sites More sharing options...
khasperha Posted June 12, 2007 Author Share Posted June 12, 2007 Hi No one have this config? ... 3dlabs + Linux = or Thanks Quote Link to comment Share on other sites More sharing options...
fox541 Posted October 29, 2008 Share Posted October 29, 2008 HiI've got a wildcat realizm 100 cg. I follow the install driver and modif xorg.conf But no acceleration !!! I tried RHEL4 and CentOS 4.5 same problem! glxinfo name of display: :0.0display: :0 screen: 0i am very sorry with you headache,and i have a wildcat6110,so i can only use my h in windows.3Dlabs refuse to develop any linux drivers,and now it closed the vga. Quote Link to comment Share on other sites More sharing options...
khasperha Posted November 28, 2008 Author Share Posted November 28, 2008 Hello, Thanks for the reply But now i gave it up Quote Link to comment Share on other sites More sharing options...
