Daniel Posted June 5, 2007 Share Posted June 5, 2007 I would think this would be straight forward, just can't find it. I have a bunch of GEO_Vertex stored and I'd like to find out what face a vertex belongs to (if any). This isn't possible with GEO_Point since it could be a list of faces.. but with a vertex I'm guessing it's either none or 1. I can't find a method to return that given a vertex. Any thoughts? thnx d Quote Link to comment Share on other sites More sharing options...
crunch Posted June 5, 2007 Share Posted June 5, 2007 Daniel said: I would think this would be straight forward, just can't find it. I have a bunch of GEO_Vertex stored and I'd like to find out what face a vertex belongs to (if any). This isn't possible with GEO_Point since it could be a list of faces.. but with a vertex I'm guessing it's either none or 1. I can't find a method to return that given a vertex. Any thoughts? thnx d I don't believe that the vertex has a back-pointer to the primitive. So the only way to find it would be to search every primitive. If you're doing this a lot, you might want to build your own list of back-pointers... Quote Link to comment Share on other sites More sharing options...
rjpieke Posted June 5, 2007 Share Posted June 5, 2007 crunch said: I don't believe that the vertex has a back-pointer to the primitive. So the only way to find it would be to search every primitive. Fortunately "every primitive" does not have to mean EVERY primitive. If you use a GQ_Detail to represent your geometry, you can use the FOR_QUAD_EDGE() macro to iterate over the point's shared faces to see which one actually contains the vertex. Cheers! Quote Link to comment Share on other sites More sharing options...
