zoki Posted June 6, 2007 Share Posted June 6, 2007 Hi could someone plese explain a little difference and usage of all those options under geometry in render tab of geometry sop? I used render as subds and procedure sprites but other file options and all the bounds are still not clear to me I checked help and there is not much written in it I want to setup files so that I read points from disk into named geometry sops then instance on this points and use those geometries randomly on new geo to be insanced on scatered points thanks z Quote Link to comment Share on other sites More sharing options...
rdg Posted June 6, 2007 Share Posted June 6, 2007 (edited) ll the bounds are still not clear to me If I got it right the "bounds" discard points of the file that don't lay within the SOP. Edited June 6, 2007 by rdg Quote Link to comment Share on other sites More sharing options...
zoki Posted June 6, 2007 Author Share Posted June 6, 2007 ok this is one checked off? Quote Link to comment Share on other sites More sharing options...
