Tyreprint
Hey man
how close do u get to this trail?
like a skid mark?
if u check the file, make sure u render the rop sop :-)
this might work for what u doing ;)
:blink:
Thank man. Your help is really appreciated.
Yes, I am doing a skid mark. My car is drifting towards the camera, and I want o have a skid mark left on the ground (sand). My ground has a VEX mountain applied to it as well. I have one stupid question. If I follow what you did in the hip file...should I use the alpha to displacement map my ground (my ground has a texture on and displacement map on to gain a look of sandy ground)?
this is my test render of the ground.
thanks again
cherm
Hey
yeah, i suppose, if u want to give the illusion that the ground is being perturbed: convert that vop network into a displacement shader, just use the Cd value to displace the normal.
or convert that shader into a sop and displace the surface based off the point cloud, however a high level of detail displacement will have to have a heavier ground mesh because the points are being displaced, thats why it may be a better idea to do it in a displacement.
but if u just need a quick solution, id definately go with sops.
let me know if u need a example file
:blink:
Hey
:blink:
Hi there,
i think i need an example of how to convert that shader into a sop and displace the surface.
Thanks a million
tyre_v2.hipnc
Hope this helps,
:blink:
Thanks man. it's very helpful. I have one more question about deep shadow map. If I have to render 150 frames do I have to render deep shadow map (.rat) for every frame? Or I just created once?
Thanks again. you saved my life big time.
When it comes to shadow maps: if the object that Casts a shadow is moving... then u have to recompute shadow maps.
& if nothing is moving, then obviously only one shadow map :-)
:blink:
:blink:
hi again,
i rendered 10 frames out just to check the shadow maps, but it seems like all 10 .rat files (the shadow maps) look exactly the same. correct???
cheers
