futurechad Posted June 16 Share Posted June 16 Let's say I have a Cube that I animate in some random way by keyframing the Transform SOP. How do I get what I have drawn in Red as a Curve? i.e. The path followed by the centroid of the Cube? Quote Link to comment Share on other sites More sharing options...
futurechad Posted June 16 Author Share Posted June 16 The following is the solution I received: Use Extract Centroid SOP in Run Over Mode Detail to get the centroid, put a RigDoctor SOP after, then a Motion Clip SOP, then a Motion Clip Extract SOP with Output Mode set to Motion Trails Quote Link to comment Share on other sites More sharing options...
