Stremik Posted January 20, 2003 Share Posted January 20, 2003 Could someone of those who has a dual (Windows/Linux) boot system tell me, How do you browse Windows directories from Linux? Do I need some utility for this? Which one? Thank you. Quote Link to comment Share on other sites More sharing options...
TheUsualAlex Posted January 20, 2003 Share Posted January 20, 2003 Hey there, In KDE (I am using KDE now), you should see "Home" on your desktop. Just click on that. It's kind of hard to explain on text (I think), but once you opened up that one, just play around with the icons. Find an icon that looks like a file folder on the middle of the explorer (where you see bunch of icons). That'll show you root directories which include ALL folders in the system. In Gnome, do the same thing, but I think that the explorer is a bit different compared to KDE. Another method is just browsing via shell terminal. I highly recommend you to get "Linux in a Nutshell" --I highly recommend -- (from O'Reily) for command reference, and probably get one of those Red Hat Linux book (I have "Red Hat Linux 8 Bible") They're pretty helpful for me in terms of knowing enough of the basics to get me very comfortble with it. Hope that at least helped a little... ALex Quote Link to comment Share on other sites More sharing options...
miguel m Posted January 20, 2003 Share Posted January 20, 2003 Is the partition(s) fat or ntfs. Also let me know if you're using a custom or stock kernel. If you want you can search for the file /etc/fstab and post here the contents, just to make sure we will not be reinventing the wheel on your linux. Quote Link to comment Share on other sites More sharing options...
