Sprite Collision Advice
photex
Hi all,
I was just wondering what techniques you use to prevent sprites from sticking out of collision geometry.
If I set display to points I can see that the collision pop is doing what I ask, but once I start using sprites, or render the particles, sprites near the edge clip through the collision geometry.
And advice?
Thanks,
chip
I would take a look at the Translation POP. That enables you to offset instances, so basically you will want to offset it by the size or your sprite.
Ahhhh. Cool thanks. I ended up just scaling the collision geometry to a size that would contain the sprites better. I figured there was a pops way to do it though.
