Questions About Evalstring
Hi
I've got a couple of questions about evalString, first off what are the
last two parameters(int vi and float t) suppose to represent/ control
void evalString(UT_String &val, int pi , int vi, float t);
void evalString(UT_String &val, const char *pn, int vi, float t);
my second question is about int *pi in the following:
void evalString(UT_String &val, const char *pn, int *pi, int vi, float t);
What does it represent and when would you use instead of the other two?
Many, Many, thanks
L
Edited by doc
As I understand it (and I may be wrong) float t is time - ie in channels that can be keyframed it tells the eval function when on the timeline to evaluate the parameter.
I don't think you can key frame strings so I'm not sure if its their just for possible future compatibility, i always set it to 0.
int vi is the component you want to evaluate - ie in a 3 float vector it would be 0, 1 or 2
Again in a string I'm not sure you can have more than 1 component so again I always set it to 0.
As for your second question, I'm not sure... sorry
(extracted from OP_Parameters.h)
vi : vector index
pi : parameter index
pn : parmeter name
v: vector component (if v == -1, all components are affected)
If you know the parameter index, it might be faster to use it for the lookup, rather than the parameter name. But, unless you're doing this thousands of times, it's probably not worth it.
Cheers!
Edited by rjpieke
You should always pass the proper time when evaluating parameters even though most legacy code didn't. Even in H8, it could cause cooking problems. For example, if your string parameter uses vtorigin() for some reason, then it will return the result at time 0 instead.
