Newbie Questions
petz
Hey Petz
Yeah there actually there is, infact im doing that right now on a project where i am uzing an image to dictate how deep ice shards should be extruded,
look into the expression
tex (string, float, float, string)
what u can do is extrude the surface by no value and then use the point sop + tex expression to perturb the surface.
via using the same expression u can ie modify the normal via ie - sin (tex ("default.pic", $BBZ,$BBX,r)*360) and then when u copy ur objects onto the point.
take a look at the file attached.
hope this helps.
brian
extrude.hipnc
