christianl013 Posted September 20 Share Posted September 20 Hello, I have been doing basic tutorials on Apex in order to start learning how to use these awesome tools for animation. I am very stuck on one thing that has stopped me from moving forward on this and I was hoping someone more knowledgeable could lend me a hand here. I have been following the most basic example as has been given in the Apex masterclass on setting up a tube with proximity capture etc. Everything seems to be as it should be however I can't get any translate or scale controls to work when I am in pose mode with the autorig component or even the animate node. They are all grey'ed out when I press the G key and all I have available to me is rotation. I have been trying to solve this for hours but have not made any in roads on this and this posting is my last hope. When I tried the stock nodes like add prop the controls worked fine but when I dive into that one its final node is a python node, so it's clearly no using the rig components node. Anyway, if anybody can help me here I would be grateful, thanks! Best, Christian Quote Link to comment Share on other sites More sharing options...
christianl013 Posted September 20 Author Share Posted September 20 ok, I solved this. It looks like the transforms are not exported on the component node by default, you have to specify to export them and then it works. Best, Christian Quote Link to comment Share on other sites More sharing options...
SHo0N Posted 9 hours ago Share Posted 9 hours ago Hey Christian, if you don't mind, can you explain your solution some more because I'm encountering the same problem for days now. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
