How To Make Make A Ripple With Cube Matrix?
tankboy
  mike said:
hi,
here is very simple solution with the vex-ripple SOP....
maybe this helps.
I have read the file, thanks for your idea,amigo. It helps me so much.:D
  GallenWolf said:
Oddly enough, I can't seem to attach stuff to a post?
Anyways, here's another version using the Ray SOP and a torus :)
Link
GW
Thanks,amigo.
The effect is what I want. :D
Edited by tankboy
  tankboy said:
...But please pay attention to the pic,I wanna the wave appear
only once.
I think that the point was to demonstrate an idea that might be extrapolated upon, not to spend time tailoring a solution that caters specifically to your needs. If there's anything else that we can do for you, please, by all means, let us know.
  stu said:
I think that the point was to demonstrate an idea that might be extrapolated upon, not to spend time tailoring a solution that caters specifically to your needs...
You are right, stu.Thanks for your advice.:D
Edited by tankboy
