MADjestic Posted August 5, 2007 Share Posted August 5, 2007 Hi, I thought about enveloping a gfBmV4D function as a VOP type, I read this thread http://forums.odforce.net/index.php?showto...p;hl=Outer+Code and found some valuable tips, but still seem to miss something obvious. So here's my code: Outer Code: #include <math.h> #include <gNoise.h> vector gfBmV4D(vector p; float rough; int maxoct; float blur; float time) { vector4 pp = set(p.x, p.y, p.z, time); gNOISE_FUNC(vector4, noise(pp), pp *= 2 ) } and Inner Code: $var = gfBmV4D($pos, $rough, $maxoct, $blur, $time); Looks too simple to work, and, in fact, it doesn't. Any from top of the head ideas why it doesn't work? I thought this VOP Type could be useful with the recent SESI FX Tools, so that to change the default 3d noise VOP for a 4D noise. Thanks. Quote Link to comment Share on other sites More sharing options...
MADjestic Posted August 7, 2007 Author Share Posted August 7, 2007 I think I managed to wrap up the code in a single node, VEX code looks all right, doesn't show any errors, however it outputs 0. I created a simple network showing the case - look inside the D4 Noise VOP for details, or the shaders' VEX Code. If somebody has time to look inside the attachment - I would be grateful. Thanks. func_v05.hipnc Quote Link to comment Share on other sites More sharing options...
edward Posted August 13, 2007 Share Posted August 13, 2007 It doesn't look like you have the HDA definition embedded. Quote Link to comment Share on other sites More sharing options...
MADjestic Posted September 9, 2007 Author Share Posted September 9, 2007 It doesn't look like you have the HDA definition embedded. Problem solved. $blur was 0 and thus causing 0 output =] It doesn't look like you have the HDA definition embedded. Problem solved. $blur was 0 and thus causing 0 output, and some wrong variables types =] Quote Link to comment Share on other sites More sharing options...
