Random Numbers With Hscript/windows
lisux
Hi everybody.
I am making an hscript tar is embeebed ito an OTL, is a section of the otl and is called by a button as a callback script.
I have to use H8 on Windows (unfortunaltely :( )
And well my problem is the nex I ned to get a random number per every execution of the script, because the time and date commans in windows are unusable for this task I have decided to use the time hscript command calculating the time of recursively list all the nodes in the scene,if you use the next in the textpor it should work correctly:
set randN = `rand(strreplace(run("time(\"opls -R / \")"), "r", ""))`
Basically it calculates the time of the opls command, rid of the r in the time result and make a rand over it.
My problem is that this chunk of code works perfectly in the textport but when I try to inclue it in a callback script for a button in an otl it fails.
I know it is failling because I put a message comand after the code and it doesn't appear, a little hack to debug hscripts in otls.
Can Somebody give me any clue about this?
Thanks
