Double-sided Texture
I am going to texture a leaf geometry and I'd like to use a double-layered shader, 1 texture for the frontal face and 1 for the back face of the leaf.
Note: I did take a quick look to the layer sop but I just managed to overlay 2 textures. I think I need to take the face normals into acount but how?
Thanx in advance
cheers
you should just be able to do this by testing against the "I" vector against "N" if
the value will be -ve or +ve depending on which side is facing the camera.
here's some code (I haven't tryied compiling this)
if(dot(normalize(I),normalize(N))<0){
//back face code
else
//front face code
hope that helps
//back face code
else
//front face code
hope that helps
Hi doc,
thanx for the reply. I kind of understood the logic and tried to apply the code in VOPs , however, I couldn't manage to get it right.
Could you please be more specific. (I am not that experienced on VEX // VOPs so... :blink:)
thanx in advance
I managed to get it work. with the formula that you gave.
However, I have used the switcher VOP node instead of using "If then Block" node. Because "if node" didnt work ( it couldnt read the 0 input).
Am i doing somehing wrong ?
what are the principles to use "if then block" node
Hey I don't have an output on my "if-then-block" node.
I know sounds a bit strange but there is no output :unsure:
I am able copy from the help file though.
Did this happende any of you guys before or Am I doing something wrong again :P
cheers
Cheers, Symek
that helped.
Its a bit wierd though that you need to get in and go out. maybe it depends :P
anyways it works now
Thanx again.
well, the point is that this is a container for your stuff. That's why you jump into it. In many cases you want to make some job there - like in case of if-then statement in normal "hand written" code.
good luck!
sy.
yep, that make sense. :P
I did a quick interface for the this double sided. The parameters that I put are quite basic. If you guys would like to change the interface interms off adding some other parameters or whatever.
please feel free about it.
Here is the hip file that I created by the help of "doc" and "Symek" ., that contains the VOP network.
double_sided_texture.hip
cheers
cheers
Why not just use IsFrontFace vop to a switch? No need to wire up globals.
