Prm Type For Sop Node Browser
Hello all,
So I'm looking for a PRM TYPE for a parameter that allows the user to
browse for a sop(similar to the the "object1" parameter in the object merge sop).
Unfortunatly I'm having a bit of trouble finding it in "PRM_Type.h". Can
anyone point me in the right direction?
Many thanks
L
ie. use &PRM_SpareData::sopPath() instead. It's also useful to use OP_Node::getSOPNode() to look up the path since you can pass true to the second parameter to have extra inputs automatically added. This function will also handle cases where it's an object path instead (and thus use the render/display sops as appropriate).
