Trim !
rob
When using a trim SOP following a project SOP. If you select keep inside on the trim you get left with lots of points in the scene on the surface that recieved the projection.Whats the best way to get rid of these.
fixed ....
follow it up with a convert SOP and turn off that default check box saying keep original !!!!!
R
Edited by rob
