Mark_98217349 Posted February 12, 2025 Share Posted February 12, 2025 Hello! I am new in Houdini. I try to make a ammo wooden crate using IndiePixel AmmoCrate tutorial. But apparently not all things work for me or I didn't understand how to do something. My box doesn't scale correctly on some axes and I don't know how to fix it. Can you please help with this? Quote Link to comment Share on other sites More sharing options...
AntoineSfx Posted February 18, 2025 Share Posted February 18, 2025 No one can help you without some kind of information about the SOPs you're using Looks like there is a misconfigured Match Size SOP somewhere that is scaling uniformly instead of by scaling by axis.. Or something like that. Quote Link to comment Share on other sites More sharing options...
Mark_98217349 Posted February 19, 2025 Author Share Posted February 19, 2025 22 hours ago, AntoineSfx said: No one can help you without some kind of information about the SOPs you're using Looks like there is a misconfigured Match Size SOP somewhere that is scaling uniformly instead of by scaling by axis.. Or something like that. Yes, I forgot to publish the file. Wooden_Crate_04.hip Quote Link to comment Share on other sites More sharing options...
AntoineSfx Posted February 20, 2025 Share Posted February 20, 2025 23 hours ago, Mark_98217349 said: Yes, I forgot to publish the file. Wooden_Crate_04.hip 156.91 kB · 2 downloads you have at least one syntax error in the node that has an exclamation point ch(",, instead of ch(".. coma instead of point And there is some logic error in the various formulas, because it doesn't scale correctly as you noticed. The trick is, fixing your work is basically as hard as reverse engineering your paid tutorial. If it works in the tutorial, double check each formula from the author if he doesn't provide a hip Quote Link to comment Share on other sites More sharing options...
Mark_98217349 Posted February 23, 2025 Author Share Posted February 23, 2025 On 2/20/2025 at 4:20 PM, AntoineSfx said: you have at least one syntax error in the node that has an exclamation point ch(",, instead of ch(".. coma instead of point And there is some logic error in the various formulas, because it doesn't scale correctly as you noticed. The trick is, fixing your work is basically as hard as reverse engineering your paid tutorial. If it works in the tutorial, double check each formula from the author if he doesn't provide a hip Ok, thank you! Quote Link to comment Share on other sites More sharing options...
