etudenc Posted February 22, 2025 Share Posted February 22, 2025 Hello all, I feel I should know this by now but I can't seem to figure it out. I wish to pack a high number of non-symmetrical objects together fairly tightly. In my SOP network I've copied a cube to a bunch of scattered points. The result is brought into a DOP network and solved with a rigid solver. For every step I want to push each simulated object back down to its original position in Y (some pieces start to ride their neighbors and I don't want that), and I want each object to maintain its original orientation, which I guess means that for every step it gets set back to the original orientation. I tried a geometry wrangle but it doesn't seem to have any effect - I'm probably just not setting it up correctly. For what it's worth, the simulation works fine, I just need to figure out how to push each piece back down to its original position and set it back to its original orientation. Quote Link to comment Share on other sites More sharing options...
