v2n Posted September 6, 2007 Share Posted September 6, 2007 (edited) Hi All, I'm trying to render some curves with the Fur Mantra procedure. It works ( no error message ) but not as expected. I create three attributes ( furdensity, furtipwidth and furrootwidth) and save the skin with those attributes. In the Mantra procedure, the three attributes are transfered from the skin geometry like this : -t "furdensity furtipwidth furrootwidth". Only the furdensity works. The width keep the default setting of Mantra rendered curves. Here is the complete Mantra Procedure : fur -s $HIP/skin.bgeo -g $HIP/guide.bgeo -t "furdensity furtipwidth furrootwidth" and here is a repro scene : http://www.vol2nuit.fr/guillaume/houdini/Proc_Fur.rar Any tips would help ! Thanks ! Guillaume PS : I know Fur is updated in H9 but I use Houdini 8.2.154 with the fur proto install. Edited September 6, 2007 by v2n Quote Link to comment Share on other sites More sharing options...
Wolfwood Posted September 6, 2007 Share Posted September 6, 2007 (edited) The furtipwidth and furrootwidth attributes were used in a very early version of the fur tools. Now you just use the standard rendering attribute 'width'. Proc_Fur.tar.gzFetching info... Edited September 6, 2007 by Wolfwood Quote Link to comment Share on other sites More sharing options...
v2n Posted September 6, 2007 Author Share Posted September 6, 2007 Wolfwood said: The furtipwidth and furrootwidth attributes were used in a very early version of the fur tools. Now you just use the standard rendering attribute 'width'. Thanks a lot Wolfwood ! ( I just changed the uv texture sop from "natural location" to "point texture" in order to get your expression works). Cheers Guillaume Laforge | La Maison Quote Link to comment Share on other sites More sharing options...
v2n Posted September 6, 2007 Author Share Posted September 6, 2007 So now, the fur procedural render is fine but... motion blur isn't . I use something like this : fur -c 0.8 -s skin.$F.bgeo -g $HIP/guide.$F.bgeo $HIP/guide.`$F+1`.bgeo -t "furdensity" -T "width" From the Houdini 8.1 fur help "-c" is the correct syntax for the shutter speed. Is it the same for Houdini 8.2 ? Thanks Guillaume Quote Link to comment Share on other sites More sharing options...
Wolfwood Posted September 6, 2007 Share Posted September 6, 2007 v2n said: So now, the fur procedural render is fine but... motion blur isn't .I use something like this : fur -c 0.8 -s skin.$F.bgeo -g $HIP/guide.$F.bgeo $HIP/guide.`$F+1`.bgeo -t "furdensity" -T "width" From the Houdini 8.1 fur help "-c" is the correct syntax for the shutter speed. Is it the same for Houdini 8.2 ? Thanks Guillaume fur -c 0.8 -s skin.$F.bgeo -g $HIP/guide.$F.bgeo -g $HIP/guide.`$F+1`.bgeo -t "furdensity" -T "width" Search the SESI forums for the Fur.otl, its a front end for building these strings for you. (Assuming you are using Houdini 8) Quote Link to comment Share on other sites More sharing options...
v2n Posted September 6, 2007 Author Share Posted September 6, 2007 Wolfwood said: fur -c 0.8 -s skin.$F.bgeo -g $HIP/guide.$F.bgeo -g $HIP/guide.`$F+1`.bgeo -t "furdensity" -T "width"Search the SESI forums for the Fur.otl, its a front end for building these strings for you. (Assuming you are using Houdini 8) Thanks again . Your digital asset looks very usefull. Quote Link to comment Share on other sites More sharing options...
