paranoidx Posted March 13, 2025 Share Posted March 13, 2025 (edited) How can I merge multiple files from nested wedges? I used the Lab File Merge, but it has no method to input array second index; there is only a single $SLICE index. In my case, I need another index. Example: Wedge total 8 of 2 [0][0] [0][1] [1][0] [1][1] Currently, I have to use the $SLICE index for the first index, and enter the second index manually. Is there another way to auto-load it like $SLICE? P.S. I see there is a list of indices that seems like it will solve the case. However, I don't know what string pattern to put into the filename when loading. Looking for info. ** I thought case closed by this solution List Of Indices: each $SLICE is an index, so the pattern in the filename when loading is just to put each $SLICE between a separator or any pre-defined character. Ex: $SLICE.$SLICE. However, my case has 11 wedges, with each wedge having another 2 nested. It loads only the first 2; it seems the max $SLICE doesn't pass 2 because of the second index. Edited March 13, 2025 by paranoidx Still not solved. Quote Link to comment Share on other sites More sharing options...
